Mallardgrn
- Oct 18, 2017
- 1
Engine starts and idles and will run in gear on a hose with ears.....put it in the water and it runs in idle but put it in gear and try to put power to it it dies. I've gotten it to run on idle in gear but as soon as you turn the throttle it dies. I've replaced coils, new fuel pump, rebuilt cards, new plugs, new cold start solenoid, new stator trigger.....I'm lost....just noticed last time trying to start after replacing stator trigger that the flywheel key is bad but we are pretty sure that's a new development.
