merkdawg0084
- Oct 11, 2017
- 573
Yes i have a 1984 evinrude 9.9. I have bought a new vertical gear and pin,the inner control shaft gear. I repainted the lower cowl and now in the process of putting it all back together. For all of the gears to work in unison with the throttle handle gears.what is the correct way to install these? I've worked on motors before, just not all of gears. thank you
