Thumbs up,
I'll rip it apart after work today "again" and see what I come up with with that spring. I'll take a picture and see if I can label it with numbers, maybe some form members can jump in and comment, or even better maybe someone can scan a couple of pages outa a good shop manual and post em on tuning sequence.
After work,
I pulled apart the throttle linkage and it's a combination of the old stiff wire covering fron the timer base and lube that touches any of the linkage. I cleaned it and used a dry lube and the timer base follows the throttle linkage nice, it's worth a note that tempature has a huge impact on any type of greasy lube you use.
There were some funny wavey washers tossed in linkage too with the cottepins , all these little restrictions add up and lessen the spring effectiveness. I have learned since starting this that you never know what the previous owners have done and have put back wrong or just guessed at, and where washers went after sitting on a bench for many weeks.
One of the biggest issues I found is the previous owner had 1&2 plug wires mixed, not to mention all 10+ tiny things that add up to "why won't this tune " . All said, I've had it almost perfect on the water , this motor will push a 94 16.5ft campion to 60kmh/37mph.
So if I'm rambling it's because I think they're worth saving, providing you don't need to re mortgage the farm and you have something worth saving.
