Over heat alarm going off at cruising speed but stops at lower rpm. From research I'm thinking possibly thermostats but more likely flow deflectors in heads. A couple questions: Can thermostat housing be removed without removing power head? To clean out water jackets in heads and replace deflectors do I access through exhaust cover or do heads need to be removed?
