Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Lost cowling for 1978 4hp Johnson.
  • Lost cowling for 1978 4hp Johnson.
    4W78E I lost the cowling today on the way to the lake. I have a parts motor but it was missing the cowl when I bought it. There is a seller on EBAY that says the cowls from 1969 thru 1978 are interchangeable. If someone could please confirm that because I have found a couple that I want to go see. But they both appear to be early 70s cowls. Also I would assume an Evinrude cowl would fit? Thanks for any help given.
    Cjeck the part numbers out on shop evinrude to see
    • #3
      They have different part numbers but I believe that is because of color and graphics.
      • #4
        Anyone know how to start a new post?
        • #5
          I believe that unlike the 6-horse engines, both the Johnson and Evinrude 4s share the same lower shroud, meaning that the hoods will interchange. Actually the 1968 3 horse as well as 1969 - 1978 4-horse hoods should fit.
          The above is true for North American motors.
          Cam Milne
          1950 Johnson 5 - TN-26
          1955 Elto 5 (Gale 5 based) - 5D11E
          1956 Eatons Viking 5 (Gale 5 based, incomplete) - 5D12V
          1958 Johnson 7Ĺ - AD-12
          1967 Johnson 9Ĺ - MQ-13
          1971 Evinrude Yachtwin 4 - 4136D
          1976 Johnson 15 - 15R76
          - all from freshwater and built in Peterborough
          "None of us is as smart as all of us"
          • #6
            Thanks. I did check the part numbers for the lower pan and 78 had a different number. There is no high speed needle on the 78 so maybe that is the difference.
            • #7
              I don't think there is a simple way to replace a cowling, unless you find the same year and model online. I would look for outboard boneyards if you have them around (old time shops or marinas) -- need to have the same latch mechanism, appropriate openings choke knob and carb needles and knobs.
              • #8
                The latches and front and back hooks are the same from 1969 thru 1978. And the rubber seal is also the same. So the only difference I see is shape which could be a problem because I have external ignition coils and a different flywheel. There are no openings in the cowls themselves so no problem there. The ones I saw that were an exact match on Ebay would end up costing me over 100 dollars.I would rather try to find a complete motor then pay that much. I know a few places I can check. One is close and the other is 1 hour away.
                • #9
                  I am pretty sure the earliest of the 4s used different lower cowlings for the Evinrudes vs. the Johnsons. The Johnsons had a different shape to the cowling and the lower pan/cowling was a different shape to fit them. I believe the Johnsons used the same shape all the way through their run, so if you stick with a Johnson cowling, you'll be fine. The difference toward the end of that run in the lower cowlings was they added bosses to mount the power pack when they went to a CD ignition.
                  Share A Project Page for 1971 GW Invader Banchie 13
                  http://www.shareaproject.com/pages/p...,p,433,00.html
                  Share A Project Page for 1976 American 18
                  http://www.shareaproject.com/pages/p...,p,404,00.html
                  Share A Project Page for 1974 American 15
                  http://www.shareaproject.com/pages/p...,p,405,00.html
                  • #10
                    Yes I will be looking for a Johnson cowl. When I do find one I need to find out why it wont stay on. It has come off once before, and I thought it was because I did not secure it well enough. There does not seem to be any adjustment on the latch, like on some of my other motors. And it was kind of a sloppy fit. If I pushed back on it the hook on the front would pop out of the slot. And it sometimes rattled while running.I have not had the cowl off for a couple months. When I found out that it had come off the latch was still locked. So I guess it came out on the front and it blew off.
                    • #11
                      worked on a neighbor's mid-70s 6 about a year ago, and detailed the hood (fun to work on). I know the hoods go for big bucks (too much, imo) on eBay -- bought one for a '90 4 deluxe a while back (not sure now what I paid). I like the idea of picking up a parts motor for just the hood (and whatever other parts turn out to be useful at some point). Always feel I get my money's worth that way.
                      If you get one that needs restoration, I found vinyl decals on eBay for the 6, and turned out very nice.
                      • #12
                        I've found a few loose cowlings over the years - usually due to the belly pan having been distorted at some point. Doesn't take much. Motors get tossed in pickup beds, car trunks, etc. Gas tanks get put wherever. Stuff gets pinched, bent, warped, etc.
                        • #13
                          The guy I bought from was the original owner and it was used a few times each year. When I first saw it the cover was off and running in a barrel. It looked almost new and then I saw the hood. It was chipped and scratched and missing a lot of paint. He used at his camp in the north so it traveled logging roads and bush trails every summer for 30 plus years.
                          • #14
                            Check the top secret files at the beginning of this forum for salvage yards. You may find one there.
                            • #15
                              Okay thanks.
