Going to put new plugs in my Johnson 85hp V4. I see most of the application charts say to use the QL77JC4 plug, which appears to cross reference to the 828M plugs (which I also see referenced here often). I also found one page that listed the 828-1 plug as a cross, and looking at Champion's web site, they appear to be identical in all regards to the 828M, including being listed as a QL77JC4 plug type and a Q-type inductive suppresor. More importantly, they're available today, on the shelf at my local parts store, whereas the 828M is a special order item.
Is there some reason I shouldn't be running the 828-1 plugs? I'm wondering if it's just one of those things where a part number was slightly changed for one specific vendor/reseller...
