Good morning,
So i recently bought an old Larson tri hull boat and it has a 73 Johnson 115 hp on her that the lower unit has basically rotted away. With the boat i was also given a 73 60 hp Johnson which is in perfect running order. My question is are these lower units able to be swapped or do i have to take gears out of one and put them into the other?
