Catfishcabin
- Apr 2, 2017
- 103
So me and a friend of mine picked up a 1973 four-cylinder 85 horsepower Evinrude for his 18 foot pontoon boat it had been sitting for probably about five years we did a little bit of work to it and seems to run really strong out of the water but when we put it in the water it runs great until wide open throttle. We get wide open throttle for about eight seconds and then the motor begins to Surge and bog until we dial back the throttle lever and then it Smooths out. We've replaced the fuel pump fuel lines clean the carburetors replaced the coil packs replace the rectifier replace the vacuum line and we're still having the problem. The only thing that I've noticed looking at the motor this time is that there's a crack in one of the stator coils? Could this be our issue or maybe even timing or points?
