1976 40 hp stuck in reverse
T.Jass42
So I took the boat out this morning and was working fine but when I was wrapping it up and about to head back to the boat ramp, the boat wouldnt go forward, seems like it is stuck in reverse, so I thought it might be the linkage so took i took off the cable and put in forward and nothing happens, doesn't feel like it's going into gear really loose idk please help
boobie
Sounds like some linkage on your motor fell apart. Look up a parts breakdown of your motor and check it against your motor. Or else take it into a shop.
175se
Dang pressed the wrong key, did you do a water pump lately, had one do that last week.
T.Jass42
It was the shift rod coupler, put it back together and now it works thanks guys
