Darrenkmac
- Oct 1, 2013
- 29
Hi everyone. I have a 94 model 174 Evinrude that is pushing a 92 Ranger 481 V. It cranks and revs up fine with no problem idling. When I take off, it moves forward and slowly builds up speed until it finally reaches plane and then the boat takes off like a rocket. I have no problem with top end it seems. This problem has progressed from the spring into the summer and seems to be getting worse. This past Saturday it took over 100 yards to finally come on plane. I had changed the bulb, thinking that it may have been the problem but with no results. I have a Hot Foot and I have looked at the linkages and they seem ok. my controls appear to be ok. I am running a digital powerpack and this motor ran very well in the past. I had no problem pulling a tube with the boat. My prop is a 24 pitch Raker and I have not changed props recently. I was wondering if my VRO may be weakening perhaps. It still uses oil from the oil tank so I know that both oil and fuel are still mixing. I don't have a lot of white smoke either. The motor seems to be winding up slowly so to speak as my speed increases going up to plane, then it is like something kicks in. I am flooring the Hot Foot to get it up to plane and then I have to back off as it takes off to keep from over reving it seems. Any ideas are appreciated. Thanks, Darren
