osuchica1284
- Aug 21, 2017
- 26
Hi, just bought a well used 1983 Wellcraft v20 with what was listed as a Johnson 200 VRO because that's the decal wrap on the motor cover. Just got home and unloaded and now I'm trying to obtain info so I can start sourcing parts BUT no placard on the motor anywhere!!!! I called a local shop here in sunny Florida and they said with no placard, you're SOL.
Is there anyway I can identify the year, model motor through other means? I already took the engine cover off and didn't see anything outside of some engine components with (part?) numbers embossed in them. The 200 VRO WAS offered on those hulls back in 1983 so up until now, I assumed it was original ...
Let me know if you want / need photos of the motor. Thank you!!!!
