I posted a few years ago about this and thought I had it fixed but looks like I didn't. I've had this reoccurring failure usually right after starting the boat, not always on the first start, where the back of the ignition switch smokes and the boat won't start back up. It does crank and the choke still work but it will not fire. I was using a Sierra switch and noticed that the Magneto connector arced from one terminal to the other. I switched back to an OEM switch and sprayed the back with plastidip and was hoping that was the fix as it seemed to work for about a year. I took the boat out this morning and as soon as it started the switch smoked again and was toast.
After getting back to the house I pulled out a spare switch again and started looking at the burned switch along with an old burnt one I kept. The inside of the switch isn't getting burned up even though you can smell burnt on the back of it. I hooked up a bad old switch and it even worked again. So it doesn't actually seem to be frying the switch maybe just burning the back of the terminal some how. I measured the voltage for the magneto wire and it's running at almost 1000 volts.
Only plan of action I can see right now is to clean and check each connector. Load test each wire. Add some dielectic grease to make sure its got a good contact. Currently the only preexisting issue I have is the dual mode timer base has cylinder #5 not working on cold start. Can't say if this would cause any weird issues. The timer base is only a few years old but unfortunately was faulty from the factory.
Any suggestion would be greatly appreciated.
Edit: 89 Evinrude 150 XP
