The motor will start and run good at idle but as I throttle up it stalls. Does this sound like a blockage in the carb? The carb seems to only have one ajustement needle and that seems to be a low speed needle. It also speeds up when choked. Suggestions? One other issue is that the key on the control starts the motor but it will not shut it off. I've been choking it out to stop it. Where would I start looking for that problem?
