Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Johnson Starter Problem
  • Johnson Starter Problem
    OK, starter runs, gear goes up, doesn't engage flywheel all the way, make horrific noise. Someone on another forum said solenoid, replaced that, same problem (down $40 and 1 hour work). What next? Got video of problem. Will post soon. Thanks in advance! (motor is a 198? Johnson28)
    Welcome aboard:
    I moved you out of the cartoons section into Johnson outboards to see if we can get something rolling for you.
    Flywheel and starter are both in the right position? No teeth missing?
    [ATTACH=CONFIG]temp_270443_1499813187632_202[/ATTACH]
    • #3
      Load test the battery.---Take starter apart and inspect brushes.
      • #4
        That problem almost always is the starter isn't running fast/suddenly enough. Check battery, battery cables. Do some voltage tests. However, with the noise comment, I'd suggest the starter gear or flywheel gears might be badly worn or damaged.
        • #5
          You say it makes a horrific noise (the bendix?), if so... and if the starter armature is turning inside of the bendix gear, replace the bendix.
          Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
