Greetings all! I would like to change the rope pull start on my 1982 Johnson 7.5HP (J8RCNR) motor with an electric starter motor. I use it as a trolling motor on an 18' Starcraft. Works like a charm once started, but due to ever-increasing arthritis, I'm enjoying the starting ritual less as time goes by. I'm hoping there is a starter motor that will due the job. I'm not sure such a thing exists.
I've attached a pic of the existing pull start mechanism. From much search, I think this:
http://www.iboats.com/mall/partfind...&gd_poid=242414&gd_row=2&session_id=670016441
might work, but I'm not sure of 2 things:
1. The pinion on the existing pull-starter is 13-teeth, but all electric starters I've seen are 9- or 10-teeth; I'm guessing (hoping) the gear pitch is "standard" and the starter motor pinion is just smaller diameter.
2. Mounting points; the existing pull-starter has 2 bolts at the bottom and 2 at the top. I need to know the dimensions to be sure it will fit.
So, if anyone has done this upgrade, or knows for certain what part# will do the job, I'd sure appreciate your help.
Best Regards!
Best Regards!
