I am having a issue with my engine starting and running after sitting and fishing for a while . Engine will do a cold start and run fine , planes out out and runs great till you fish for maybe a hour or more . When you go to move will start but can not accelerate , will die and cut out and you have to sit and feather the the throttle to get it running again . After that it will run with no issues . I have done compression check and all are 140,140 136, 140,140 136. I have also done spark test and it all looks fine .Ihave also checked all the the fuel lines and can find no fuel or air leaks from the tank to the cabs. The ball does not stay real tight and have replaced it three times just to be sure . When I try too to pump it tight it floods the engine . Any suggestions on what to try next ? I have also read that these engines are prone to heat sink issues . Are there any ways to avoid that issue ?
