Ibrettfavre
- Jul 7, 2017
- 1
The plugs I pulled out are called "surface discharge" plugs and it's the first time I have ever encountered them, they're also really hard to find.
The motor cover says "champion L77JC4", and the plugs I pulled out said "champion L77J4". The J4 plugs are the surface discharge plug, and the JC4 plugs have the electrode like most plugs you see.
My buddy said not to use the plugs with the electrode on that motor because the piston will keep hitting it and eventually tear it up, that would cost me alot as I have pretty much no knowledge when it comes to small engine rebuilds.
I've searched high and low and I can find no information about my situation, also every time I try to research the plugs using the model number of the motor it always directs me to some plugs with electrodes, which leads me to believe it's ok to use them but the boat has always run great with the no electrode surface discharge plugs. "Don't fix what ain't broke" right?
Also, the model number of the 25 hp Johnson motor is 25r277h
Can't post a picture of the surface discharge type plug for reference but here's the url:
https://www.google.com/search?q=cham...0S625MsJ_GgQM:
