can the 1989 40 hp fuel pump be repaired with a kit? manual says no but i see they sell a kit for it. had to keep pushing primer button to keep it running to get back to dock,seemed to run ok the other times i had it at full throttle, but almost every time at start up it would run right up until i was ready to shift it into gear but would quit, unless i kept pushing primer. so assuming it could be the pump, squeezing the fuel line bulb did nothing.--thanks----tom
