Hi all in my quest for a transformed engine i need help on one point just now.
I am going to add these carbs (Fitted with choke plates) I will remove these (I think????)
I want to run these with a primer solenoid which is already on my engine ( Johnson V4 85hp)
I know it can be done but i cant find any info on how to do it. I read somewhere that you buy a service kit for or gasket for the new type of carbs then there will be a hole in the gasket that you drill out and fit a nipple to which you attach the two small rubber hoses from the primer solenoid. Is it as simple as that???
I know i will be re jetting the carbs and rebuilding them. So at present i don't need info on the carbs, just a pointer in the right direction on what to do.
In a nut shell do i just drill the holes fit the nipples and disregard the choke plates ????
Or do i keep the plates in place ????
Or should i go for the choke solenoid over the primer ????
Any help with a pic of where to drill would be great.
