thank you all for the responses. I have had this motor for 7 years and it is certainly not normal fuel dump. This year in particular I've noticed more fuel/oil leakage, than previous years combined.
It doesn't backfire when the motor runs, but just while trying to start it every now and then. So i'm not sure if that would be considered an actual backfire, though i think my linkages are fine being its ran for years without me changing anything.
My spark plugs have good spark and when i finally do get it started it runs as good as ever.
i'm not sure how to decarbon, but i'm sure the google machine will help with that.
The float is the correct side up and the needles are adjusted correctly (I've done a lot of work on the carburetor in the past). The float could be sticking, but the primer bulb (2 line pressurized tank old style) does stiffen up when priming, so wouldn't that mean the float is shutting off correctly?
I've had a lot of problems with this motor in the past, and most of them come back to the carb, but this time i do think it is something internal being that i pulled the carb a couple times already and haven't found a problem yet. However my knowledge of the internal workings is pretty limited.
i have noticed that after priming the motor and pulling the rope several times it does drain the carb bowl. So i'm pumping a lot of fuel through the motor, for some reason it doesn't fire and works its way out the exhaust. I hope cleared the water a bit to this muddy question. any more advice will be appreciated.
