Re: Gear adjustment? Where is my problem? 1998 50 HP Evinrude
Wow now see if this rings true to anyone. I looked into my control box and found part # 0390610, it is the shift gear lever. Anyway the plastic behind the last tooth on the forward direction is worn down just enough that when you move to engage is has a moment traction loss. So that explains why some times I could get it in but most of the time it was just out of range of engaging for both directions. It is no longer made so getting one is bear. like $125.00 for an OEM part originally listed as $25.00. I did find that you can modify part # 0387726 to fit. So I did a little digging and found one on Ebay. For a temp fix I think I will get some sand paper and attach it so it will grip and turn. Anyone ever have the same problem?
