SeanGold007
- Jun 22, 2017
- 15
I recently purchased a 1993 18ft bass Buggy that had been sitting for a couple years. All the seats and console were trash. After rebuilding console and putting back on boat the neutral switch on throttle was not working so I connected the two wires to a toggle switch. Motor will turn over battery is fully charged but no fire plugs are wet. I pulled each plug and attempted to check for spark but nothing. What can I check to find the problem. Lady I bought it from said never had issues and it was winterized when she parked it. I do know on the wire harness to the tilt/trim switch on console there is a brown with white stripe wire that i don't know where it goes i overlooked it when taking console apart. Also the neutral switch was working before I took throttle control out of old console. Could I have a wire not in the right place or is there something else causing no start????
