I took it out on the water turned up the warm up lever lower took off went about 30 yds then the motor cut out at about quarter throttle I think it might be a blocked fuel line
Maybe time to look over the entire fuel system to include the carbs. If you haven't disassembled them and install carb kits, I would do that first. But that is just my thinking. JMHO
It stalls whenever i go to give it full throttle it gets to about 50% throttle then dies. The only time it stays running is when the warmup lever is up
