Hey all! I've been reading this forum for a number of months now to learn as much as possible about my motor and problems that may arise with it. All has been great until today. I'm pretty much a novice with outboards but I'll do my best to explain. I have a 1995 Evinrude 130hp v4 looper. I always start it on the hose before I bring it out to make sure it's running. Yesterday, after ensuring that the primer bulb was firm, it took about 6 tries before the motor started (usually takes about 2), I had to actually give it some throttle but it started and ran fine for the rest of the day. Today, no problems on the hose or for the first half of the day. I did a mix of idling, cruising, and intermittent bursts of WOT. I was idling through a no wake zone and the motor died (it does this sometimes at idle but always starts right back up), it then took a few minutes to get it started again (this is highly unusual). I gave it a little throttle and finally it started. It ran fine for another 20mins or so until we stopped to swim. We stayed for about an hour and when it was time to go, the motor wouldn't start. I ended up requiring a tow. Back at the house, I pulled the plugs, they were wet, and turned the motor over a few times in case it was flooded. All plugs had a spark. The lower starboard plug didn't spark at first but after I cleaned it, it had spark. There is oily film in the water running out of the motor so I'm pretty certain I'm getting good fuel flow. Checked the fuel also and looks clean. It is fresh, ethanol free fuel. Once, on the hose, it did sputter some but I turned the key again and nothing. I'm pretty baffled here as I have spark, fuel, and air flow. What am I missing? Any help is much appreciated! I have since changed the plugs and discovered that my primer solenoid is leaking and not sending fuel to the carbs. I tested this by removing one of the lines connecting to the carb from the solenoid and depressing the key. I have a solenoid rebuild kit on the way but I don't think this would cause the engine not to start, right? I plan on checking compression tomorrow when I fix the primer solenoid. Any ideas?? Thanks in advance!
