T0mmyboy
- May 4, 2017
- 12
Hi all,
I recently got a 35 horse evinrude electric start only model for my little Crestliner. After hooking up all the controls I proceeded to fire it up. It fires right up with the push choke, and will stay running if I throttle it up, but will quit if I try to let it idle. I think maybe the idle is set too low? Is the idle speed adjustment on the side of the motor, on the throttle cable where it attaches to the engine, or is is that plastic screw at the base of the cable?
Thanks for the help
Thanks for the help
