etec 25
ozarkrivers
Hey ive got a 25hp etec. Unsure of year. Have to check in the morning. A guide had to be towed in the other day on the river. Would barely start and will not rev. Now wont start at all. Waiting on program and cable to do diagnostics. Any thing common with these to cause such an issue. Fresh fuel. Changed plugs. And changed fuel pump for a spare we had here at the dock. No improvment.
ozarkrivers
So got it hooked up. Shows code 12 14 and 52. Tps is first two. But 52 is injector 2 circut open. Any ideas?
jakedaawg
How many occurrences of each? Which code was the recent ones or were they all recent? Usually I find a bad lift pump in these.
ozarkrivers
Engine will not start at all. Those all showing each time tested. Do not date back past day of breakdown
ozarkrivers
But also. The tps voltage is within range. Showed it is out of idle range though. Install a new one. Still shows the same. Also what is a normal emm temp for these with power on
ozarkrivers
This ended up being the computer causing the fuel injector failure. Wasnt sending correct power. Hope this helps someone!!!
