[FONT=Verdana, Arial, sans-serif]Picked up this motor from a guy who decided to go for 4 stroke.[/FONT]
It is 25 Johnson 1992.
The motor was a kicker and occasional trolling.
After initial carb cleaning, all necessary adjustments it starts right on the 1st or second starter touch. No problems here.
[FONT=Verdana, Arial, sans-serif]But here is the issue, opened the lower to change the impeller and here what i found. Is it a sight of a blown motor or it just accumulated because he never ran it at WOT. I know it for sure because the starter cable was holding the throttle lever not allowing it to move more than 50%.[/FONT]
[FONT=Verdana, Arial, sans-serif]What do you think is the problem if at all?[/FONT]
[FONT=Verdana, Arial, sans-serif]Unfortunately the system does not allow me to post attachments/pictures,
