Anyone happen to know whether this gap can be adjusted when installing a new timer base? The existing one shows signs of rubbing. Could be because the flywheel trigger magnet epoxy had fractured loose allowing it to be hand removed. The alignment notch however was still aligned with the factory paint mark on the flywheel. Have this puppy apart to replace a tired stator that was beginning to drip the dreaded tarry goo onto the upper crankcase area. Will likely just order a new timer base along with a new stator while one can still be got. Already cleaned up the old epoxy residue and re-glued the trigger magnet to the flywheel using BRP epoxy. These issues seemed to have arrived a few months after a plastic bag wrapped around the water intakes causing an overheat that dropped the engine into S.L.O.W mode. Flywheel got hot enough to fry and egg on. Too bad I didn't have any. Anyway, anyone that can shine some light on the install of a new timer base with respect to air gap between trigger magnet is welcomed.
