Johnson ship master parts number help
Sean102385
Just joined the site. You all have been a big help, just lurking the site for a while now.
I am installing a Johnson shipmaster and was looking for this part number and this helped me but I need to see if you guys can help me with two more part numbers. I need the part numbers for the sleeve and set screws that go into the end of the casing guide to hold the cable. Numbers 22 and 23 on this diagram.
Thanks in advance.
Vic.S
Try the BRP parts lists
Screws .......0308037 .... 4 required
Cable clamps .......0308036 .... 2 required
But check
jbuote
Sean102385
You guys and the knowledge you have are amazing. Thank you so much. I will look into these at it appears they are what I need. Will let you guys know how it works out!
jbuote
IF you look at the assembly link, I believe it's just 1 clamp and 2 screws.. Vic beat me to it by seconds, and he has part counts..
​So, you MAY need 2 assembly kits IF that's the route you go.. Just FYI... :)
