OK, I had an issue with the motor bogging down,,,after rebuilding the carb's, changing the fuel pump (to the new style) and fuel lines..I took the boat out today...I tried starting the motor ..it would not start...I sprayed a little starting fluid into each carb and the motor would run and idle high.. The motor would idle at times but hard to start again...I thought it was because of the new fuel pump..So I sprayed a little starting fluid into the carb's and the motor started right up but it ran pretty high...I closed the choke by hand and it seemed to idle ok.. And off I went the boat planed very well no issue's... about 2 miles out the motor died and would not start again I tried pumping the bulb the fuel bulb seem to get a little hard, but I saw no fuel going into carbs..had to use my trolling motor to get me back in...(that was a long trip)...not quit understanding why it's not getting fuel sometime's and none other times Does any one have any idea's what could be going on with this motor....
Thanks Mav
Thanks Mav
