I have been chasing issues on my '79 70hp Johnson for a year now. I started with a fuel pump rebuild, then a new fuel line and primer bulb, rebuild of all 3 carbs. Still doing the same thing. Seems to start up and idle alright, when you throttle up it bogs down and the boat will top out at 6 knots. In testing the spark on muffs today I can pull the plug wires off the center and bottom cylinders and that will make no difference in how its running. When I pull the top plug wire the boat will die. So to me this means the bottom 2 cylinders are not getting spark, or at least very weak spark. Do I start with coils or power pack? Also when unplugging the plug wires I was getting small zapped from the bottom two cylinders, but not the top. Connectors and the nut at the terminal on the coil are also quite corroded, moreso on the lower 2 cylinders.
