jbuote
- Aug 17, 2016
- 1,001
Howdy all!!
This is going to sound silly, and I feel silly for asking, but...
The #1 cylinder on my 71 Johnson 50hp 2cyl, is the top cylinder, yes?
I can't seem to confirm that with my manual..
Anyway, the reason I'm asking is because I'm still trying to get her running reliably.
She'll run sometimes (well, got started 3 times so far), but it's a pain getting her going...
Previously I had:
new battery
cables and connections cleaned throughout
Batt connections tight (with wrench, nut not wingnut)
Rebuilt the carbs, and set floats properly.
Checked compression and spark, both were good. Comp well above 100 and even, spark open air 7/16 gap, crisp snap, blue spark both cyls....
Set low speed needle valves on carb to 1-1/2 turn out from seated (lightly, not TIGHT seated.. lol).
Fresh gas/oil mix
Fuel sprays from inlet hose when disconnected from carbs and turning over, so fuel delivery up to carb is working.
Used correct cold starting procedure. (Including setting lever to "Start".. I've missed that step before.. :facepalm
I'm probably going to either rebuild or replace the starter soon as after a few times trying to start her, starter slows down and warms up.
Let the starter cool off and it's back to good starting speed for a few attempts.
She'll turn over fine (starter speed as described above), and "Pop" from the exhaust often, but usually that's about it except for the 3 times she actually started and ran.. Sounded pretty good too when she ran...
Figured I'd check the timing of flywheel by putting eraser end of a pencil in the Top cylinder, (both plugs out, batt disconnected) and hand turn flywheel till pencil won't come out any further and then see if timing pointer was at or VERY near the TDC mark on flywheel.
Figuring that might tell me if key sheared and/or flywheel shifted on crankshaft.
What I found, was when the TOP cylinder is at TDC (or as close as I can get it via pencil), the timing marks are at the BACK of the engine, closest to the spark plugs, and about 180degrees from the timing mark on the crankcase...
So, as would follow, the BOTTOM cylinder TDC (again via pencil) has the TDC flywheel mark lined up with the timing pointer on the crankcase....
So... Either somehow the flywheel shifted 180 degrees, (sheared key etc...)
OR
I'm wrong, and the BOTTOM cylinder is #1 and things are as they should be....
OR
I've had a major brain malfunction and didn't find TDC of the cylinder anywhere CLOSE to correctly....
Sorry so long winded here, but was hoping to answer most preliminary questions I could envision ahead of time... LOL
I appreciate it in advance... (sigh...) lol
Thanks!!
Previously I had:
new battery
Fresh gas/oil mix
OR
OR
Thanks!!
