Hey Guys, did some searching and wasn't able to find this specific issue. I have an '96 Evinrude ocean pro 150 and it ran great all last season. developed a leak between the VRO pump and the vapor separator. So I replaced that gasket. All sealed up it fires up right away, no hesitation (whereas previously it would be a bear to start from cold but would run like a dream. Idle has been rough for a few years now). it will only run for about 30 seconds, pretty rough, then die. After a few cycles of this, it needs to sit for 10-15 minutes before I can start it again.
Doing this on the trailer using ear muffs. It's never acted this way before. Have not given it excessive throttle so unsure if that would keep it from dying.
Any thoughts on where to start to diagnose this??
