I have had a J15RENM some 5 years now; Very happy with it. In north Idaho, I store it 6 months a year under fogging oil in a 40 deg f shed all winter. Last year I suffered several bad fuel pumps until finding a good one. I run non ethanol premium gas with Evinrude XD50 lube. I today, sprayed OMC Engine Tuner into the carb per instructions, let sit three hours per instructions, then ran per instructions in bbl one hour and she still smokes. She has good compression 110 psi, Starts on first pull. I have run AC, Champion, Ngk plugs, she likes the ngk best but still smokes. Plugs come out clean but oily. Is this normal for a 25 year old engine with good compression?
