Hi all,
So I removed the wrong screw while familiarising myself with my engine and changing oil, which has had a flow on of regrettable events, though after repositioning the shift lever and attempting to set shift rod height, I unscrewed the rod.. I believe the cradle is now on the bottom of the shift shaft, if that is wrong and it is supposed to be on top, can I move it without taking out the prop shaft components??
Any helpful advice appreciated.
Dan
Dan
