So I picked up a jw-14 this is my first run with an outboard motor and I'm not getting fuel into the motor. It will run a bit if I put fuel in the cylinders but will not stay running.
So far I've cleaned the carbs and made sure the float and needle were working properly. All the ports were clear. Not sure what's going on. Any suggestions?
