JASinIL2006
- Feb 10, 2012
- 5,548
Hi all, I have a 1990 pull-start Johnson 4 hp outboard (model J4RDHESR) that has a broken recoil spring on the starter mechanism. (The spring snapped right near the end that attaches to the cup assembly.
My first question: is this a fairly simple repair that I could do myself? I'm not a mechanic, but I am reasonably handy with my hands and tools.
Second question: which service manual covers this motor? I've found two that seem to overlap: I've seen one titled "1973-1990 EVINRUDE JOHNSON OUTBOARD SERVICE MANUAL 2-40 HP" and another titled "1990 2001 johnson evinrude outboard service manual 1 hp to 300 hp." Since my motor is a '90, I'm unsure which one might apply. (I've been looking at the latter manual on Boatinfo, but the reproduction is pretty bad; the photos are so grainy they're pretty hard to make out.)
Third question: assuming the correct manual, are there any undocumented tips to make the job simpler? I know when I replace the bellows on my main boat, there are some tricks and techniques that make the job much simpler that the manual does not mention.
Thanks for your help!
jim
jim
