One cylinder is not firing. Have 100 plus compression on all 6 cylinders. Have good blue spark while cranking and fuel in cylinder. Pulled plug out it's all carboned up. Disassembled carb and cleaned out. All plugs are new. Is it possible there is no spark while running. I also swapped coils with a cylinder that is firing.
Thanks for the help.
Warren
Warren
