I just purchased a 92 Johnson 40 HP VRO with Tracker Pro Series Controller. I hooked it all up but was getting an steady alarm. But the when I turned the Key the engine would spin. Today I figured out my Alarm issue. The wire harness that should plug into the Oil Pump was plugged into the plug for the trim controller on the engine side. They have the same plug. But the Trim has an extra wire. Anyway When I plug the oil pump in to the wire harness correctly the engine will not spin. Acts as if I have a dead battery. But if I plug the oil harness plug into the trim the engine spin. Seems really weird. Any ideas?
