matt_southbound
- Apr 24, 2017
- 2
I recently purchased what was advertised as a 1996 Evinrude 4HP (I looked up the model # J3RED online, and it looks like it is actually a Johnson 3HP - not a big deal though). The seller started it up for me without a problem, and it ran fine for the 5 mins we ran it.
Fast forward to a month later, and I can't get it started on the back of my dinghy. After emptying the tank, adding new fuel, and checking spark plugs, I still couldn't get it going. I decided to take off the carb and clean it up. This did the trick, and now I've got it running.
This is the first outboard I've ever had (although I have done some work on my inboard diesel before). Although it is running now, I've got a few questions/issues that I can't seem to find the answer to.
1) There is a small knob next under the pull rope. Pulling it out turns the choke on, pushing it in turns the choke off. You can also turn it a quarter turn clockwise. This cuts off the fuel to the cup with the carb float switch. Straight up and down the fuel valve is open, filling the cup.
My question is what are the proper settings for starting and then for running, and when would you ever want the knob to the right, so that the fuel valve is shut off?
2) I'm not sure I have the idle screw set correctly. When I start the motor with the choke on, it will run for a few seconds then die. If I turn the choke off, allowing full air intake, it starts and runs fine. This is the opposite of what I thought would be the case. I'd imagine that it would run easier initially with the choke on because there would be more fuel in the mixture.
After I start it, it will usually idle in neutral or in gear OK, but sometimes it dies. If I ride around with the throttle open for a few minutes, then drop down and try to idle, it will die, and I don't know why. Maybe that's just how these motors are?
Any help very much appreciated! Thanks!
