1973 Johnson 115 power tilt only pump
Kloctower
I have been trying to buy a new motor or rebuild kit for the original tilt motor but I can't find anything. I have looked around and I just can't find the parts. Please advise gents. If anyone out there can identify this electric motor with a part number or maybe lead me to a website for more information that would be great because I have nothing.
Parrothead71
I have the same one. Parts are few and far between...when you do find them they're expensive.
I've been looking at replacing the motor and pump with a unit from an I/O that will be in the boat and out of the water. Better parts availability too.
Kloctower
So there is no company making units right now? I found some that look alike but I don't know about part numbers
Force outboards and Suzuki outboards have similar units on much newer models.
Kloctower
No Title
I just found out from Evinrude that the company that made those units was sold to Arco. So I called Arco and they said they are still producing these replacement motors and that this is the correct one.
Kloctower
No Title
This is a aftermarket off brand
Kloctower
Just a close up here this fixed my problem. If you are having my issue​ then order this motor it will work on this motor.
