jsparks747
- Apr 12, 2017
- 77
I picked up a 1970 Johnson 9.5 Sea-Horse at a neighbor's for $80 and am hoping to replace the rather beat up and dented prop. The problem is that it doesn't use the grooves like more modern engines and propellers, but uses a simple rod that goes through the shaft and locked into the back of the prop. I have been looking for a while anh have found plenty of props that are meant for the same make and model but they don't have the slot for the rod. Any suggestions?
