clemsonfor
- Sep 19, 2005
- 1,011
1998 evinrude 60hp
Ok so this is my first time doing the waterpump on this motor. Got it diconnected fine. Did the pump kit. Adjusted shaft length to spec. Put the thing back togeather and am having a difficult time catching the hole in the shaft with the pin on the bell crank. I am reaching right over the lower unit to turn it to try and align it with a pair of plyers, tried to press it toward ot with a screwdirver. Maybe I havent tried long enough but this can't be this difficult? I took ot apart in reverse and assembling in reverse, all the way down...now I'm thinking did I put it back in reverse after I measured in neutral, but I am pretty sure I did? I guess I can double check that, but anyone have any other tricks?
