blacktrain
- Jul 20, 2013
- 59
Well here I am back again. Got the spark problem fixed, now the motor has no power. Starts right up, when you open up the throttle the rpm's go up but not much above a high idle. I can screw in the high speed jet all the way in and it makes no difference the motor runs the same. I did clean the carburetor, but no change. As i move the throttle I do notice that the butterfly in the carburetor is opening up like it should. I also checked the reed valve to make sure it's not sticking or cracked. As always, I appreciate everyone's help. Thanks...
