jhetrick55
- Apr 21, 2017
- 83
In the fall of 2016 I purchased my first boat - a 1988 Sierra, 16' Fiberglass fishing boat - and it came with a 1975 70HP Evinrude engine. I took it out once in the fall before I worked on the interior all winter in my garage. It started hard, but ran after I used the manual choke. The only issue I noted was a lot of smoke upon starting for the first time in I don't know how many years. I was pretty happy it ran at all.
Come spring of 2017, I take the boat out and start it up the first time, a lot of smoke, but again its running seemingly well as the engine warms up. I take the boat out again a few days later, smoke upon starting, but runs well. This happens several more times, along with having to use the manual choke to start the engine nearly every time, and I am starting to think there is a bigger problem.
Long story short, I take the boat in to a dependable mechanic and his assessment is that water is getting in the center cylinder and it must be a cracked block. I read up on this to find out it could also be a head or exhaust gasket. I take the boat elsewhere for a second opinion. The second opinion tells me they didn't even get to the place where they ran the engine to know if water is getting in, but they have found scoring on the center cylinder - to what extent I will find out tomorrow morning.
So, my question is: Will the engine run with scoring (compression tests have 125-130psi for compression in each cylinder) if I can find the source of water getting in? Tomorrow morning I am meeting with the latest mechanic to have him show me what he is seeing. After that I may be able to make a better determination about proceeding by buying a different engine or repairing this one.
In the meantime, any thoughts or experiences will help. Thanks!
