greenhornet97
- Dec 21, 2008
- 11
I have a 1974 Evinrude 50 hp twin cylinder outboard that runs great .... until I shift it into gear with the Power Pilot shifter that came with the motor . It doesn't matter if I shift into forward or reverse . I get about one inch into the shift stroke and it dies just like I shut off the ignition. I shift back into neutral and the motor fires right up again instantly. Is there an electrical switch in the shifter that needs replacing ? I can't imagine that it would be the throttle or shifter cable attachment in the motor . Any suggestions would be appreciated . Thanks !
