Hey all, so got my new to me Johnson running smoothly in a bucket. However, I noticed a few of my sparkplugs aren't looking so good. My top starboard spark plug seems to build up with carbon pretty quickly, while all the others don't seem to have this problem. I don't run it more than 3 min and it becomes pretty discolored. I was running some gumout in my gas, so I switched over to just regular mix gas and it's seemed to have helped a good amount (not as much buildup, but still more than all other plugs). Checked for air leaks in lines and seems all good, also it's getting spark, but when I pull the wire when running it doesn't seem to make any difference (no change in RPM or missing sound). Kind of confused what could be causing this because motor seems to run fine; starts right up, no hesitations when throttling up or down, and maintains idle and higher rpm just fine. Amy suggestions would be great, thanks
