I have a 2001 Johnson OceanPro 90HP 2-stroke that drips a black goopy ooze after I run it. Engine has maybe 600-700 hours on it?not a lot for the year (no HourMeter). This happens regardless of whether I run it for several hours or even if I run it (with flushing muffs/running water) on the trailer for 5-15 minutes. The amount of ooze depends on how long I run the engine. If I run it for 10-15 minutes it makes a couple ?shot glasses? (maybe 2 liquid ounces?) of black goop. If I run it for several hours out on the water (ocean?saltwater) , then put it back on the trailer and flush with flushing muffs, it produces more?I would guess maybe 4 ounces (that drips out over a period of several days). The black ooze comes out of the center of the prop and also from behind the prop ?I will try to post photos tomorrow (this outboard has through-the-prop exhaust, of course. And it automatically mixes oil into gas). Sometimes I run non-ethanol gas but mostly I run E10. I have used several brands of oil (including Evinrude/Johnson 2stroke Premium) and see no difference in ooze production. The black ooze does not appear to be coming from Lower Unit lubricant?I removed the top filler hole in the Lower Unit and a bit of lubricant spurted out?so I know that the Lower Unit lubricant is not being consumed/depleted to form the black ooze. I have 4 other small outboards (3.5 to 6HP) and they all leak a bit of combustion oil, but not nearly as much as this 90HP outboard. This outboard has been dripping this ooze for at least 3 years and thus far I have seen no harmful effects. Overall this outboard does not smoke much (for a 2 stroke) and in fact one of my most knowledgeable boating friends (40-50 years with outboards) feels that this engine smokes very little. There is no fouling of sparkplugs?they burn a nice tan color and get replaced every 3 years or so.
The boat seems to have plenty of power?as much as I ever remember it having (although over the 15 years I have owned this boat I have not kept good GPS-quality records of speed at various RPM?s). So I don?t think a cylinder (or 2) is (are) not firing. But I understand cylinder(s) not firing could be the problem?with powerpack or shift interrupter switch often being the root cause. A couple years back I had 1 cylinder not firing and as I recall there was a noticeable loss of top end power/speed.
I am taking my boat to get a non-engine-related problem fixed this week, and would like any ideas/input you might have so that I can discuss this ooze condition (I?ll avoid calling it a ?problem?) further with my mechanic. Thanks
