Seanymph35e
- Mar 31, 2017
- 1
I can get my boat to about a 1/4 throttle and it bogs down in the water. Out of the water it will go all the way up in gear and with just the throttle. Power pack just went bad but it did that before. I replaced the tank, spark plugs, fuel line from motor to tank. Carb was rebuilt last year. I'm thinking of changing the fuel pump assembly since it doesn't like to seal all the way sometimes and possibly rebuilding the carb again. Linkage on the timing and carb look to be working properly. Any thoughts or suggestions?
