Faststroker383
- Mar 23, 2017
- 24
Ok Guys I now have the Intake and crankcase taken apart and I found that the bottom rod bearing has basically disintegrated completely. I assume from oil starvation although another Evinrude mechanic said that it could be a plugged up carb. Either way, here is what I have so far...
https://goo.gl/photos/Tjufu6hoh998Tqpx6
I guess at this point I'm looking into pulling all the pistons, re-hone, new rod and wrist pin bearings, gasket set and carb rebuild. Anything else you guys can think of before I order the parts?
It looks as if the VRO was / is working due to oil gas mixture in the other cylinders. I'm not positive whether I want to disconnect this or just rebuild it. I like the idea of keeping it IF it works and will be reliable. My thoughts are to keep it and also keep enough oil to add to the tank case of an emergency. This way I would get the benifit of the VRO. Maybe I should put on a VRO2?
